Dovetail Logs
Ebbman
Normally, I use "Coped Logs" but in Chief the process is similar.
1.  I use a Wall Type that's the Wall Thickness - basically an almost Invisible material.
2.  Insert all Doors and Windows into these walls.
3.  Place Symbols of the Logs centered on the walls (half height Log one directionwith a full height Log on top of it)
4.  Place a Full Height Log in the other direction.
5.  Replicate the Logs up the Walls just as you would when actually building the structure.
  • Downvote 1
