Material bleeding through on door jambs
RL-inc
  • 1 year later...
On 11/8/2016 at 3:03 PM, dshall said:
I bet you do not have interior casing on your garage doors.  In regards to the other doors,  I have not a clue without a posted plan.
I just came up with this issue, so thanks for posting the 'solution', or workaround for bug.
I also found that you could add the interior casing and simply set it at 0" width, which will then display as if no interior casing was used.
