Raised floor on post foundation.
ACADuser
First one of these for me but can't get it to auto build.
I used my template file so maybe my defaults are not set correctly.
Called a cabin due to it small basic design. Nothing special just framing floor & foundation.
Thanks
Plan deleted (Wrong version of Chief sorry)
Alan, are you referring to post and bean on top of pier pads (no foundation wall and footing)? If so the program does not do it automatically.
To do post and beam just create a blank foundation, set reference display to fist floor, draw in your beams, add post (round or square) with pier and add your joists. All parts go in at the proper heights. If you want it elevated just lower the terrain and post and piers should automatically adjust.
I have drawn several of these types of buildings.
OK using a blank plan X8 I got it to build a floor framing & I manually added beams & post w/ foundations.
Just need to adjust height of post. Maybe adding terrain will help with that.
I think the other plan had some defaults set that prevented me from creating the floor framing.
Hall 1.plan
