Kduke11 Posted October 25, 2016 Share Posted October 25, 2016 I have searched for this but can't find anything. Is this possible? I'm sure it is and I'm just missing something. LOL Thanks. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 25, 2016 Share Posted October 25, 2016 Place a Panel adjacent to the Washer and use a Custom Counter Top. Chief doesn't have a Cabinet like that. You could also just create a PSolid, Block it and specify that it's to be treated as a Cabinet and included in the Schedule. But IMO that's overkill. Link to comment Share on other sites More sharing options...
Kduke11 Posted October 25, 2016 Author Share Posted October 25, 2016 Place a Panel adjacent to the Washer and use a Custom Counter Top. Chief doesn't have a Cabinet like that. You could also just create a PSolid, Block it and specify that it's to be treated as a Cabinet and included in the Schedule. But IMO that's overkill. I have the base cabinet done that way. Needing an upper at that angle. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 25, 2016 Share Posted October 25, 2016 Same process, PSolid and just change the size and vertical position. It's just a filler no matter how you look at it. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 25, 2016 Share Posted October 25, 2016 I am a cabinet guy, having built and installed quite a few. So I like to do the details so things get built the way I expect. For the special corner cabs in this island, I used Chief to model the doors by making the "cabinet" 1/16" thick, and then specified only one door in each corner instance to show in the schedule. Then I call out in the schedule that it's a custom and I show them how it's built with a Sketchup model. Link to comment Share on other sites More sharing options...
MarkMc Posted October 25, 2016 Share Posted October 25, 2016 Angle front cabinet- blank front, door on one side-rotate, measure to fit. 1 Link to comment Share on other sites More sharing options...
Kduke11 Posted October 25, 2016 Author Share Posted October 25, 2016 I am a cabinet guy, having built and installed quite a few. So I like to do the details so things get built the way I expect. For the special corner cabs in this island, I used Chief to model the doors by making the "cabinet" 1/16" thick, and then specified only one door in each corner instance to show in the schedule. Then I call out in the schedule that it's a custom and I show them how it's built with a Sketchup model. I will play with this and see what I get. Thanks. We show interior elevations so having it look correct and functioning is a must. Link to comment Share on other sites More sharing options...
Kduke11 Posted October 25, 2016 Author Share Posted October 25, 2016 Angle front cabinet- blank front, door on one side-rotate, measure to fit. I'll see what I can do with the suggestions. Thanks!! Link to comment Share on other sites More sharing options...
MarkMc Posted October 26, 2016 Share Posted October 26, 2016 .... and functioning is a must. Notfornuttin- The installers I know would have a fit if I gave them a cabinet that was supposed to fit flush into that corner. Sure you can add scribes to each side but it's still the hard way. Don't know which way you are looking at placing this cabinet (s) ? IRL If I wanted storage on both walls then I'd be using two cabinets with a filler (or two which is what I'd order). The loss of storage is tiny, costs less and happy installer. If just one wall then a cabinet and a panel that can be scribed to the wall. 1 Link to comment Share on other sites More sharing options...
