jimmyp Posted October 6, 2016 Share Posted October 6, 2016 Hi All Title pretty much says it all. 3 stories. auto exterior dimensions would not work on floor 2 which has deck on all four side. moving one deck rail to be flush and expose one house edge and it works. I tried it in a clean plan with one floor and same results. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 6, 2016 Share Posted October 6, 2016 Jimmy, Sounds like time for some manual dimensioning. Or maybe post you test plan for someone to take a look. Link to comment Share on other sites More sharing options...
glennw Posted October 6, 2016 Share Posted October 6, 2016 By default, railings are marked No Locate - thus, no dims. Link to comment Share on other sites More sharing options...
jimmyp Posted October 6, 2016 Author Share Posted October 6, 2016 test attached. shift-A on first floor and nothing happens. shift-A on second floor and there are the dimensions.... test.planFetching info... Link to comment Share on other sites More sharing options...
Solution dshall Posted October 6, 2016 Solution Share Posted October 6, 2016 On 10/6/2016 at 12:57 PM, glennw said: By default, railings are marked No Locate - thus, no dims. That is the reason. If you do not like that, disconnect the railing at the perimeter, do the shift-a, and then reconnect. Link to comment Share on other sites More sharing options...
jimmyp Posted October 6, 2016 Author Share Posted October 6, 2016 The wraparound deck is a force field against errant dimensions:)Thank you!! Link to comment Share on other sites More sharing options...
