jimmyp
auto ext dims not work on wraparound deck
Hi All
Title pretty much says it all.
3 stories.
auto exterior dimensions would not work on floor 2 which has deck on all four side. moving one deck rail to be flush and expose one house edge and it works.
I tried it in a clean plan with one floor and same results.
Jimmy, Sounds like time for some manual dimensioning. Or maybe post you test plan for someone to take a look.
By default, railings are marked No Locate - thus, no dims.
test attached.
shift-A on first floor and nothing happens.
shift-A on second floor and there are the dimensions....
test.plan
That is the reason.  If you do not like that,  disconnect the railing at the perimeter,  do the shift-a,  and then reconnect.
The wraparound deck is a force field against errant dimensions:)
Thank you!!
    27475
    slickrick1530
    slickrick1530
