Move coordinate origin point?
DaViper
That being said, I am sure there is a way around the situation.  You may be able to select everything and shift it in relation to the origin point.  If it is the x=0 y=0 point on the base grid that you are referring to?
Well that is sort of a CAD "need-to-have" but I guess I will make do.  The issue is that some of my points exist in other sectors of the cartesian map. IE, negative values.
Next I will have to determine if I need to or can even add scale factors.
