Charlenerene Posted May 29, 2014 Share Posted May 29, 2014 So I am looking at trying to import more files. Specifically Toto toilet files but I don't know where to save the files. Unlike the CA site they don't auto install to the correct folder. I have nosed around the directory but cannot find the files. Any ideas guys? Again thanks for all the help. Link to comment Share on other sites More sharing options...
lbuttery Posted May 30, 2014 Share Posted May 30, 2014 what are the file types ? if it is a file type that CA can import you should be able to drag and drop into a plan then add to the library you can also try MENU - FILE - IMPORT and try using the import wizard(s) Lew Link to comment Share on other sites More sharing options...
Charlenerene Posted May 30, 2014 Author Share Posted May 30, 2014 It is a .bim, I figured that you would have to put it in an already existing folder. Link to comment Share on other sites More sharing options...
lbuttery Posted May 30, 2014 Share Posted May 30, 2014 Chief can't import .bim files I've never heard of a .bim file ??? I know what BIM apps are but a .bim file type ??? maybe Envisioneer ??? http://pcsupport.about.com/od/fileextensions/f/bimfile.htm you may need to convert the .bim file to a file type that Chief can use ? Lew Link to comment Share on other sites More sharing options...
Charlenerene Posted May 30, 2014 Author Share Posted May 30, 2014 Odd Toto said that the files work with all CAD programs. Link to comment Share on other sites More sharing options...
jcaffee Posted May 30, 2014 Share Posted May 30, 2014 Toto only supplies *.rfa models, which are Revit native and not importable to CA. Try searching Trimble 3D Warehouse for an skp or dae file of the fixture you're looking for. You my also ask somebody here to open the rfa file in 3ds Max and export as 3ds or obj for import to CA. jon Link to comment Share on other sites More sharing options...
lbuttery Posted May 30, 2014 Share Posted May 30, 2014 Odd, Toto said that the files work with all CAD programs Chief is technically not a CAD program .... Chief doesn't play in the .BIM pool even tho Chief has some BIM capabilities CA has so far determined that Chief doesn't need to be in the BIM pool you will need to convert the files to a format that Chief recognizes Lew Link to comment Share on other sites More sharing options...
Kbird1 Posted May 30, 2014 Share Posted May 30, 2014 Jon is right the bim models are actually .rfa files so can't be used ..... there are 2D DXF's as well but not sure that's any help ..... pity cos people around here like their toilets too..... http://www.totousa.com/Professionals/Downloads/CADDrawings.aspx Link to comment Share on other sites More sharing options...
Doug_Park Posted May 30, 2014 Share Posted May 30, 2014 .rfa files are an AutoDesk Proprietary file format. They provide an API in their application to access data in those files, although I don't know how complete it is. For us to read them would require at having their software installed or for us to reverse engineer the file format. I would look into ways to export to a non-proprietary format, such as COLLODA that we can import. Link to comment Share on other sites More sharing options...
