Rotating an arc line
capitaldesigns
In addition to using Transform/Replicate, here are 3 more solutions...
1.  Edit>Edit Behaviors>Rotate/Resize About Current Point.  Now drop a temporary point at one end of your arc and rotate it as you wish.
2.  Use the arc's dbx.  You'll need to lock the appropriate end of your arc and then use the Chord Angle to rotate your arc...
3.  Just rotate using the normal rotate handle.  You can then re-position the arc by grabbing it by the appropriate end edit handle using your center mouse button (essentially tuns any edit handle into a move handle).
