parkwest Posted August 9, 2016 Share Posted August 9, 2016 Is there a way to frame the interior partition jack's the same as the exterior corners in CA? "L" shaped with using 2 2x6's? Link to comment Share on other sites More sharing options...
CJSpud Posted August 9, 2016 Share Posted August 9, 2016 Edit the framing after you build the wall framing. Link to comment Share on other sites More sharing options...
parkwest Posted August 9, 2016 Author Share Posted August 9, 2016 This is what I was used to when it came to framing options... Does CA have something like this? Link to comment Share on other sites More sharing options...
ShaneK Posted August 10, 2016 Share Posted August 10, 2016 We have framing and wall defaults, but not like that. Link to comment Share on other sites More sharing options...
parkwest Posted August 10, 2016 Author Share Posted August 10, 2016 Thanks ShaneK. I hate to draw wall framing details... And not have it be the way I want it done. Going around and "fixing" the wall details, after the fact, sounds so unproductive to me. Link to comment Share on other sites More sharing options...
Northriver Posted August 10, 2016 Share Posted August 10, 2016 The only time I draw partition/corner detail is when their are foundation hold down (Simpson HD's). The foundation contractor installing the stab anchors might think the corners may lap one way while the framer is thinking the opposite. Nice though to see someone thinking about getting insulation behind interior partitions by designating the "L" type partition. Nice job. Link to comment Share on other sites More sharing options...
justmejerry Posted August 11, 2016 Share Posted August 11, 2016 Try playing with the wall intersection check boxes in the structure tab of the wall when you open it. Link to comment Share on other sites More sharing options...
parkwest Posted August 11, 2016 Author Share Posted August 11, 2016 On 8/10/2016 at 8:55 PM, Northriver said: The only time I draw partition/corner detail is when their are foundation hold down (Simpson HD's). The foundation contractor installing the stab anchors might think the corners may lap one way while the framer is thinking the opposite. Nice though to see someone thinking about getting insulation behind interior partitions by designating the "L" type partition. Nice job. Thanks Jeff. I took a course back in the 80's that covered design and building of energy efficient homes and still implement most of what they taught today. Reminds me of when I was suprised when I was given an award for designing and building a 3800sf house on an ICF daylight basement, heated by a ground water heat pump, that cost less than $70/month to heat in Chelsea, MI... back in 1986. I was a young kid and a lot of that stuff was unheard of then. Link to comment Share on other sites More sharing options...
parkwest Posted August 11, 2016 Author Share Posted August 11, 2016 On 8/11/2016 at 12:17 AM, justmejerry said: Try playing with the wall intersection check boxes in the structure tab of the wall when you open it. wall intersection.jpg Jerry, not sure how adjusting the wall ends would help with installing L shaped jacks where the interior wall butts up to the exterior wall??? From the lack of responses to this question, I would guess CA does not have a way to change wall framing options. Thanks for the suggestion. Link to comment Share on other sites More sharing options...
