RobWhite Posted July 18, 2016 Share Posted July 18, 2016 Is there an method within the cabinet menu to create an island base cabinet with a 200-300 overhand on the back and sides but with the standard 25mm (1") front overhang? I can only find a tab in the cabinet menu that increases the overhang on all faces. There is also a tab that allows flat sides or back, but not the fronts. I use Chief 18 Rob Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 18, 2016 Share Posted July 18, 2016 Use a "Custom Counter Top" Link to comment Share on other sites More sharing options...
MarkMc Posted July 18, 2016 Share Posted July 18, 2016 Not available in the DBX, use custom countertop. Note that you want to create the custom top for a single cabinet or you will get extra nodes that make extending the overhang a PIA. Link to comment Share on other sites More sharing options...
dshall Posted July 19, 2016 Share Posted July 19, 2016 Is there an method within the cabinet menu to create an island base cabinet with a 200-300 overhand on the back and sides but with the standard 25mm (1") front overhang? I can only find a tab in the cabinet menu that increases the overhang on all faces. There is also a tab that allows flat sides or back, but not the fronts. I use Chief 18 Rob Try this, a base cabinet with 1" overhang, but make the base cabinet 1/16" tall and raise cabinet the appropriate height above the floor. I find this works better than custom countertop. Link to comment Share on other sites More sharing options...
