buzzsaw204 Posted July 1, 2016 Share Posted July 1, 2016 hi, when drawing the stairs, is there a way to start the "starting point" and draw downward? current when i drag and draw the stairs, it's alway stairs is going up. when i start at the Landing and drag to get the number of steps i need, it's drawn upward, then i have to manually rotate the stairs 180 deg. up until now, i just been drawing stairs using this method and then figuring out manually my Riser height to get it to match. there's gotta be another AND correct method at doing this? thanks Link to comment Share on other sites More sharing options...
Solution Kiwideziner Posted July 1, 2016 Solution Share Posted July 1, 2016 use the cntrl key as you drag down Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 1, 2016 Share Posted July 1, 2016 As Eric said right mouse button OR Alt key. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted July 1, 2016 Share Posted July 1, 2016 or just use the "Click stairs" tool Link to comment Share on other sites More sharing options...
