HumbleChief Posted June 29, 2016 Share Posted June 29, 2016 I've seen this in multiple places and can't figure out how to turn snaps off completely. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 29, 2016 Share Posted June 29, 2016 I'm away from my computer so can't really test anything, but you know you can hold down control to override that right? Link to comment Share on other sites More sharing options...
HumbleChief Posted June 29, 2016 Author Share Posted June 29, 2016 Has no effect. Still snaps to something. Actually I remember that being my first confusion about this behavior - that cnrtl key would have no effect as it was my first instinct. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 29, 2016 Share Posted June 29, 2016 Larry, Maybe you could demonstrate the other cases because I am quite curious, but in the case of your electrical schedule I believe the snapping behavior seen in your video is just the text being squeezed and requiring another line, although I could not see the whole schedule. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 29, 2016 Share Posted June 29, 2016 Larry, Maybe you could demonstrate the other cases because I am quite curious, but in the case of your electrical schedule I believe the snapping behavior seen in your video is just the text being squeezed and requiring another line, although I could not see the whole schedule. I think you might be onto something. Those schedules are font/text based and so that jump is probably the distance of a single space. Link to comment Share on other sites More sharing options...
HumbleChief Posted June 29, 2016 Author Share Posted June 29, 2016 Larry, Maybe you could demonstrate the other cases because I am quite curious, but in the case of your electrical schedule I believe the snapping behavior seen in your video is just the text being squeezed and requiring another line, although I could not see the whole schedule. That's a good call Chop but doesn't seem to be the case as none of the text wraps during any of the snaps. Link to comment Share on other sites More sharing options...
HumbleChief Posted June 29, 2016 Author Share Posted June 29, 2016 ....that jump is probably the distance of a single space. Could be... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 29, 2016 Share Posted June 29, 2016 Could be... Just got back to the office and tested out...I'm about 99.99% certain it's the width of a single space. Test it with different text size settings and it becomes pretty apparent. Link to comment Share on other sites More sharing options...
HumbleChief Posted June 29, 2016 Author Share Posted June 29, 2016 Just got back to the office and tested out...I'm about 99.99% certain it's the width of a single space. Test it with different text size settings and it becomes pretty apparent. Makes sense, and hard to imagine text increasing at a steady, smooth rate, though I have to admit I did expect that to happen. Link to comment Share on other sites More sharing options...
HumbleChief Posted June 29, 2016 Author Share Posted June 29, 2016 Thanks Mike, Thanks Chop, appreciate your time. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 29, 2016 Share Posted June 29, 2016 You're welcome. FWIW, you can override those snaps by using one of the 2 outside handles, just not the handles for adjusting the column widths. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 29, 2016 Share Posted June 29, 2016 Not on my computer Michael, Not even while depressing CTRL or X with snaps off. Link to comment Share on other sites More sharing options...
JJohnson Posted June 29, 2016 Share Posted June 29, 2016 Doesn't holding down Ctrl and X allow smooth re-sizing of anything ? Would blocking the schedule allow that ? Link to comment Share on other sites More sharing options...
Chopsaw Posted July 1, 2016 Share Posted July 1, 2016 Doesn't holding down Ctrl and X allow smooth re-sizing of anything ? No this does not seem to work for schedules. Would blocking the schedule allow that ? Yes I like this and did not know this was even possible. If you Shift select a schedule you can cad block it and then resize from a corner and then explode and you are back in service. I used to tinker with the text size and the crazy fractions to resize my schedules but this is much better. Thanks soo much J.J. Chopsaw Link to comment Share on other sites More sharing options...
HumbleChief Posted July 1, 2016 Author Share Posted July 1, 2016 Ctrl X is the windows short cut for 'cut' and is hard to use in any other way. I'll try the block and resize trick when it comes up again. Thanks too JJ. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 1, 2016 Share Posted July 1, 2016 Larry, Notice I said CTRL or X not Ctrl X. CTRL works for most things in Chief and X works for Text boxes but neither work for Schedules. Chopsaw Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 1, 2016 Share Posted July 1, 2016 Not on my computer Michael, Not even while depressing CTRL or X with snaps off. That's strange. Works just fine for me. Note that I said it only works when "using one of the 2 outside handles" . Link to comment Share on other sites More sharing options...
Chopsaw Posted July 1, 2016 Share Posted July 1, 2016 Sorry, That would still be no here. Do you think there is some setting that controls that? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 1, 2016 Share Posted July 1, 2016 Sorry, That would still be no here. Do you think there is some setting that controls that? There must be. Not sure what it is though. I hadn't really played with it much...just in passing, but I tested again and realized I don't even have to hold down the control key to get no jumping using the 2 outside handles. Strange. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 1, 2016 Share Posted July 1, 2016 MIchael, Can you get the text to resize and everything that way? And I assume you are 18.3.1.2 updated. Maybe you could do a video if you have time on the weekend. Chopsaw. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 1, 2016 Share Posted July 1, 2016 MIchael, Can you get the text to resize and everything that way? And I assume you are 18.3.1.2 updated. Maybe you could do a video if you have time on the weekend. Chopsaw. Oh no, can't get text to resize like that. Chief doesn't work that way. Even using the block and resize technique it isn't working. Notice that the schedule is no longer live and that you can't explode the block to get it live again without returning to its original size (Size factors of 1.00 and 1.00). Link to comment Share on other sites More sharing options...
Chopsaw Posted July 1, 2016 Share Posted July 1, 2016 Ahh, I have been meaning to ask what screen capture software you are using because your vid's are always so good and now I will have to do a my own video on this subject to prove that it does work when you follow the directions. True I did not think it would work myself so that is why I tested it. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 1, 2016 Share Posted July 1, 2016 Ahh, I have been meaning to ask what screen capture software you are using because your vid's are always so good and now I will have to do a my own video on this subject to prove that it does work when you follow the directions. True I did not think it would work myself so that is why I tested it. I use Snagit. And I actually didn't realize we were talking about resizing text until your second to last post I thought we were just talking about resizing the schedule box side to side. Anyway, having said that, you are correct. The schedule can be blocked, resized, and exploded. It just needs to be done with the corner edit handle (I missed that part the first time). It also works using the dbx so long as the size factors are equal. Thanks for the pointers Jere and Chop. Link to comment Share on other sites More sharing options...
