Krodek Posted June 4, 2016 Share Posted June 4, 2016 Hi All I save a plan to pdf and go to print. If I send to my 13 year old HP plotter, the full size plans will print the file properly. If I send the same pdf to my business copier/printer that is cheaper to run, and try to print 8x11 or 11x17 sized prints, none of the text boxes or dimensions show up. I have a Kyocera KM-C2520 that is about 2005 vintage. I used to be able to see the text previously, now I can't. Of course, copier manufacturers and dealers are not interested in sorting out problems with "old" printers, they only want to sell you a new one. I spent some $12,000 on this printer and as a small guy, can't afford some new unit just because of a text problem with my Chief pdf files. I do use Chief Blueprint font, but there are other standard fonts on the pdf that don't print either. And the HP plotter does just fine with whatever font. So I don't know what to do. Any ideas? Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 4, 2016 Share Posted June 4, 2016 If you are using Chief X8 you can get help from Chief Architect Inc Tech Support relative to printing to PDF. DJP Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 4, 2016 Share Posted June 4, 2016 On 6/4/2016 at 9:32 PM, Krodek said: Hi All I save a plan to pdf and go to print. If I send to my 13 year old HP plotter, the full size plans will print the file properly. If I send the same pdf to my business copier/printer that is cheaper to run, and try to print 8x11 or 11x17 sized prints, none of the text boxes or dimensions show up. I have a Kyocera KM-C2520 that is about 2005 vintage. I used to be able to see the text previously, now I can't. Of course, copier manufacturers and dealers are not interested in sorting out problems with "old" printers, they only want to sell you a new one. I spent some $12,000 on this printer and as a small guy, can't afford some new unit just because of a text problem with my Chief pdf files. I do use Chief Blueprint font, but there are other standard fonts on the pdf that don't print either. And the HP plotter does just fine with whatever font. So I don't know what to do. Any ideas? Are you printing in color or grayscale? And is your PDF in color or just black and white? Also, how are you actually printing to PDF? Link to comment Share on other sites More sharing options...
Mark3D Posted June 4, 2016 Share Posted June 4, 2016 I had a problem I was using fineprint PDFs printer and it was leaving out some object but I found it was ok if I used Chiefs PDFs printer Link to comment Share on other sites More sharing options...
