ChiefuserLarkin Posted May 24, 2016 Share Posted May 24, 2016 Hello, new to Chief and still using the demo but want to create a tray ceiling in the master that follows the outline of the room out 2' from each wall, then stepped up 1' from there. How do I go about doing this? Thank you! Jason Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 24, 2016 Share Posted May 24, 2016 The simplest way would be to create a molding profile and assign it as a crown molding in the room. You will need to set the ceiling height to the maximum height - the cCrown molding will provide the lowered area. You can assign additional crown moldings with offsets if needed. Link to comment Share on other sites More sharing options...
ShaneK Posted May 24, 2016 Share Posted May 24, 2016 Use soffit tool Link to comment Share on other sites More sharing options...
BrownTiger Posted May 24, 2016 Share Posted May 24, 2016 There are several ways to do trey ceiling, Chief suggest 3 part approach: - Create a platform hole(1), platform sides - molding polyline(2), ceiling plane (3) to cover the hole. See https://www.chiefarchitect.com/support/article/KB-00738/creating-a-trey-or-coffered-ceiling-using-the-platform-hole-tool.html -Alternative would be to raise the ceiling platform (e.g. 12") and use soffit tool along the perimeter. If you assign a molding (cown) to a room, chief auto apply if to a soffit. -Joe suggestion is good too. If you intent to use Trusses I would be using (1) Link to comment Share on other sites More sharing options...
ChiefuserLarkin Posted May 25, 2016 Author Share Posted May 25, 2016 Thanks guys! Link to comment Share on other sites More sharing options...
HamlinBC Posted May 25, 2016 Share Posted May 25, 2016 I can't add anything, other than see this suggestion I posted awhile back. https://chieftalk.chiefarchitect.com/index.php?/topic/6773-tray-ceilings/?hl=%2Btray+%2Bceiling Link to comment Share on other sites More sharing options...
HamlinBC Posted May 25, 2016 Share Posted May 25, 2016 Hey, I see you're in SF. I'm just south of Watertown, and we also have a location in Brookings. If you ever need help or anything, just let me know! Link to comment Share on other sites More sharing options...
2wheeltodd Posted May 25, 2016 Share Posted May 25, 2016 There is a 30 second method if there is no room above. Use the room divider tool or invisible wall to outline the ceiling transition. Select the inner "invisible room" and change the ceiling height in the dbx to a foot higher. Super quick & moldings are no problem. The soffit method is equally qood and will give you fewer plan issues but takes a little longer. -Todd 1 Link to comment Share on other sites More sharing options...
