Fergie Posted May 23, 2016 Share Posted May 23, 2016 Hello, I'm having an issue with my foundation height, floor and ceiling heights. I'm not sure where I went wrong. If I take a cross section view, my foundation floor heights are different. I had the foundation height set at a 9' wall height but it's not working out to that. I thought it should be 109 1/2" including the sill plate. It's not. If I look at the footings they're slightly off and not allowing me to select some of the settings due to the floor above? It seems I have issues on first and 2nd floor as well. I have a 2 story living room that might be causing problems as well. I'll attach the file. I'm using x7 Thanks in advance for any input you have. Bret FergusonRanch Walkout with Widows Walk.plan Link to comment Share on other sites More sharing options...
joey_martin Posted May 23, 2016 Share Posted May 23, 2016 It all looks OK to me. You have 9' basement walls (108") minus the 4" slab, and minus the flooring thickness. Link to comment Share on other sites More sharing options...
BrownTiger Posted May 23, 2016 Share Posted May 23, 2016 I can not begin to decipher what is wrong.... I noticed you had wrong plate height in the niche, and the stairwell probably should have room divider As far as CA 108" + 1 1/2" is fine, CA will place the sill. Link to comment Share on other sites More sharing options...
joey_martin Posted May 23, 2016 Share Posted May 23, 2016 You have some invisible walls below the observation room that can be removed. As for the walkout. Those walls should really be pony walls so that the footings can be set below the frost line...if you have one. Link to comment Share on other sites More sharing options...
ShaneK Posted May 23, 2016 Share Posted May 23, 2016 Floors are better. In foundation next time make a wall type that includes the interior wall in the same layer. Structure tab in room dbx is where I did most adjusting. Ranch Walkout with Widows Walk my version.plan Link to comment Share on other sites More sharing options...
Fergie Posted May 23, 2016 Author Share Posted May 23, 2016 I can not begin to decipher what is wrong.... I noticed you had wrong plate height in the niche, and the stairwell probably should have room divider RoomDivider.jpg As far as CA 108" + 1 1/2" is fine, CA will place the sill. Thank you Link to comment Share on other sites More sharing options...
Fergie Posted May 23, 2016 Author Share Posted May 23, 2016 You have some invisible walls below the observation room that can be removed. As for the walkout. Those walls should really be pony walls so that the footings can be set below the frost line...if you have one. Yes, I haven't got that far yet regarding the pony wall. I had the invisible walls in there at one time because I was having an issue with the room below and was looking for a work around which I think is fixed now and just need to delete them. You guys are quick and don't miss much! Thank you! Link to comment Share on other sites More sharing options...
Fergie Posted May 23, 2016 Author Share Posted May 23, 2016 I can not begin to decipher what is wrong.... I noticed you had wrong plate height in the niche, and the stairwell probably should have room divider RoomDivider.jpg As far as CA 108" + 1 1/2" is fine, CA will place the sill. Made those changes - Thank you! Link to comment Share on other sites More sharing options...
Fergie Posted May 23, 2016 Author Share Posted May 23, 2016 Floors are better. In foundation next time make a wall type that includes the interior wall in the same layer. Structure tab in room dbx is where I did most adjusting. Thank you! Link to comment Share on other sites More sharing options...
Fergie Posted May 23, 2016 Author Share Posted May 23, 2016 This is one of the foundation views I was struggling with. Should have posted it originally. Link to comment Share on other sites More sharing options...
Fergie Posted May 23, 2016 Author Share Posted May 23, 2016 You have some invisible walls below the observation room that can be removed. As for the walkout. Those walls should really be pony walls so that the footings can be set below the frost line...if you have one. How did you get the foundation on the pony wall to drop? I tried to do that and it didn't work as it was working withing the height of the room? Link to comment Share on other sites More sharing options...
ShaneK Posted May 23, 2016 Share Posted May 23, 2016 Open wall dbx , select wall type and you can see the adjustment for pony walls Link to comment Share on other sites More sharing options...
Fergie Posted May 23, 2016 Author Share Posted May 23, 2016 Open wall dbx , select wall type and you can see the adjustment for pony walls I did that. What am I missing? or doing wrong? Link to comment Share on other sites More sharing options...
BrownTiger Posted May 23, 2016 Share Posted May 23, 2016 I think you manually adjusted your footers/foundation walls, you need to put them back. You floors are straight and this is normally what matters. 7 7/10"? and 8" Link to comment Share on other sites More sharing options...
Fergie Posted May 23, 2016 Author Share Posted May 23, 2016 Thanks. I didn't even know you could do that. Do you select the upper wall then tab down to footing to adjust? I think you manually adjusted your footers/foundation walls, you need to put them back. You floors are straight and this is normally what matters. Footers2.jpg 7 7/10"? Footers3.jpg and 8" Footers1.jpg Link to comment Share on other sites More sharing options...
ShaneK Posted May 23, 2016 Share Posted May 23, 2016 You can adjust footing in cross section view, and pony wall adjustment in attached pic. Link to comment Share on other sites More sharing options...
joey_martin Posted May 24, 2016 Share Posted May 24, 2016 How did you get the foundation on the pony wall to drop? I tried to do that and it didn't work as it was working withing the height of the room? When in an elevation view, select the pony wall, when the temp dimensions pop up, set the depth to what is needed. Link to comment Share on other sites More sharing options...
