Mark_Peterson
Rake Walls at Attic have disappeared.
I've searched for this one, but haven't found it anywhere.
I have 3 gable walls that have show up "see through". on my elevations and 3D views. I think I've seen this before, but for the life of me can't remember what I did.
Anyone have a solution? I'm almost done with my plan and am ready to rip what hair out I have remaining!
235 St Francis Hip Roof 03182016.plan.zip
Assuming your roofs are properly built over the walls etc., try hitting F12 (rebuild).
You can also select wall, open dbx (specification), select "structure" tab, and check "balloon through ceiling above". For the condition you show in the pic its actually how most would frame that wall anyways.
Thanks guys, and thanks for the video Johnny.
I'm noticing on my plan a few remnants of walls, items, etc.  Mainly because this is my house that I'm finally finishing the plans on after years of putting it off. I had worked on this for the last 5-6 years and I find stopping and starting isn't the best approach.
I noticed after I posted the plan that I used the object painter to try to paint those rake walls. That raised the ceiling height to 9' in the rest of the plan. But that wasn't the problem I had.
I hadn't known about the balloon wall framing option, so that will help here.
I'm almost completely done with this plan and I think something is going on with the file and it crashed about 10 times yesterday. I'm so close that I will probably finish my elevations and send it in for plan check.
At one time, all those walls generated as they should have and I still have no idea what changed to make them disappear. Maybe I'll let that go on this one and chalk it up to a learning experience.
Anyway, thanks everyone, I love this forum, people are really helpful!
Do you have "generate attic walls" on? They are very easy to do manually also. Just go up to the attic level and draw them in.
    28872
    LKEDesign
    LKEDesign
  • Similar Content
    • By mborean
      A lot of my work involves trussed roofs.  After building the trusses, I frame the roof for the facia and varge rafters.  Problem with this is that CA adds ridge boards that don't exist in trussed roofs.  There doesn't seem to be a way to frame without ridge boards or to set the ridge board dimensions at 0.  If there is a work around, I'd love to hear it.
      Also....  Is there a way to frame a roof where one roof California or over frames over another roof.  In my previous CAD, I could trim the bottom of one roof to the top of another and the framing acted accordingly.  This program even added a valley plate on top of the lower roof and below the rafters of the upper roof.  That may be too much to ask for, but one can only  hope.
      Love to hear what y'all have to say.
      Thanks in advance.
    • By mazakintegrex
      hello,
      I had no idea there was a forum.  this is great!  I have one question for any knowledgeable experts out there!
      is there a way to use auto roof planes & lock all the top heights of the roof ridges so that they all match?  I've been working on my house plan for a few months now & have created manual roof planes to do what I am kind of after, but it is a real pia when a wall needs bumped out or something is revised.  all the rooms are set to the same height, yet it generates roof planes all over the place [height wise].. I've had better results with baseline polyline manipulation, but still left with the same issue.  I want to check a box that says "lock all full gable ridge heights" & let the pitch be the variable.  basically I want full gable ridges 1,2&3 to all be the same height and span the main 3 structures of the house. but when I generate auto roofs, its a mess!
      I also need gable 3 to slope over the porch at a lower pitch and join with gable 1- auto roof bones a hip over porch, if I change the roof group of the octagon nook it gets even wilder!
      rocking with CA premier x12
      thanks in advance!
    • By RenoByDesign
      When I'm building my roof, I put in a dimension for my roof overhang and it doesn't matter what number I put in the dialog box, it only draws it at 20" deep. What am I doing wrong? I need to fix this so I can draw my roof lines correctly and send out for a roofing quote. I am using Chief Architect Premier X12.
      Thank you, Melissa
    • By Designer100
      I would appreciate any help working out this rear existing roof where we area adding a new cath gable closed in veranda gable. the btm of interior gable ceiling it 11'8" . Exist. evar hight up is 11'8" ht. we are tearing off old covered sloped 6x6 with plastic over it and adding this new gable roof. I cannot seem to get it worked out. See attached exist. pics.
      Newell
      Premier 12 x
      newell.cheatheam@gmail.com
      Foxland chase st.Sugarlan Porch roof 10.06.2020.plan
      Foxland chase st.Sugarlan Porch roof 10.06.2020.zip
    • By HibjurOnline
      Hey All,
      Please help me to create roof over a floor without walls but with only beam/pillars. I want it to be open terrace but covered from above.
      Thanks!
