DCortes Posted April 8, 2016 Share Posted April 8, 2016 One thing I am unable to accomplish is I have a closet in which I installed about 4 shelves and they are visible via camera view but not in wall elevation view. I want to be able to show then in the elevation view so I can dimension them for review. Anyone know a way this can be done. Thanks in advance Link to comment Share on other sites More sharing options...
MarkMc Posted April 8, 2016 Share Posted April 8, 2016 Temporarily change the door to a doorway, take a detail from view, dimension the detail, put back the door. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 8, 2016 Share Posted April 8, 2016 Did you try the wall elevation view ? with all the correct layers on Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 8, 2016 Share Posted April 8, 2016 I'm guessing you just don't have that layer on in your Section View layer set (or whatever layer set you're using for that section view). Link to comment Share on other sites More sharing options...
DCortes Posted April 10, 2016 Author Share Posted April 10, 2016 Yep tried it all. They are located in the Millwork layer and that's on I tried doorway and still cannot see the shelves. Only in camera view. Using wall elevation view and still no shelves. Oh well I just went into the elevation view and drawn them in manually. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 10, 2016 Share Posted April 10, 2016 Do you realize there are 3 entirely different layer sets you are using? Changing the display while in plan view won't fix your problem (i.e just because the layer is on in plan doesn't mean it's on in your camera view layer set or section view layer set. if you attach a plan you'll probably get an accurate answer. Link to comment Share on other sites More sharing options...
