SNestor
I have a condition where the first floor wall is a pony wall and the foundation wall below is also a pony wall.
When I build the foundation...the foundation pony wall does not automatically align properly with the frame pony wall above.  Have I set something wrong in the pony wall DBX or is there a way to get these walls to align properly...and automatically.
I've attached a sample plan.
Pony Wall Example 1.plan
Steve,  there are plenty of different setting that will get you your desired results.  Yours are actually fine as they are.  Just click the "Align With Wall Above/Below" tool.  I suspect you made changes to your wall definitions after you built them and then just never realigned.
Well...I tried it again and it worked.  Everything is aligned.
I think it didn't work the first time because like Michael suggested...I made some mods to the wall before creating the foundation.  I'm guess...but, if it works I'm happy.
Thanks for the help guys.
