Door Width Macro
LevisL
I have a custom macro for door widths where the feet and inches are separated by a slash (e.g.: 2/6). I'd like for this macro to recognize when I put in a double door and note it as 'DBL', plus the width of each leaf (e.g.: DBL 2/6) instead of the full door width.
This is the macro I currently have:
arr = width.round.divmod(12)
"#{arr[0]}/#{arr[1].round}"
Can one of the macro gurus guide me in creating this new macro? I know the macro needs to check the is_double_door variable and then divide the size by 2 if it is in fact double. I'm trying to learn Ruby, but I'm limited on time right now. I tried this:
dbl = is_double_door
size1 = width.round.divmod(12)
"#{size1[0]}/#{size1[1].round}"
size2 = width.round.divmod(12)
"#{size2[0]}/#{size2[1].round}"
case
when dbl = true
result = "DBL #{size1}"
else
result = size2
end
result
This results in the label showing DBL whether it actually is a double door or not. Plus, it formats the width as [2, 6] instead of 2/6. And I'm not sure what to do to divide the width by 2. I tried sticking in /2 in a few different spots in the 'size1' variable, but it just results in an evaluation error.
Levis,
Try this instead:
if is_double_door
  size1 = (width/2).round.divmod(12)
else
end
if is_double_door
else
  result = size1
end
result.to_s.sub(", ","/")
I decided to take another look at this.
referenced ? obj = referenced : obj = owner
if obj.is_double_door
  asize = (obj.width/2).round.divmod(12)
  result = "DBL #{asize[0]}/#{asize[1].round}"
else
  asize = obj.width.round.divmod(12)
  result = "#{asize[0]}/#{asize[1].round}"
end
Definitely simpler and the 1st line eliminates the need to set the "Context".
Joe is there a way to add height to this macro like 6/8 or you have to make a separate macro for that?
else
end
asize = obj.height.round.divmod(12)
result = result + ",#{asize[0]}/#{asize[1].round}"
