Rich_Winsor Posted May 6, 2014 Share Posted May 6, 2014 In the words of the late great Marvin Gaye: "What's going on?" I found this crusty old broken window online (3D Warehouse I think) but when I put in my plan I'm getting weird results. Since my plan is a little quirky (to say the least) I have put 2 of the windows into a basic 4 wall plan to isolate the problem. When viewed from one side both windows perform as expected. But when viewed from the opposite side, the window in the far wall displays in front of the window in the near wall. Anybody have any ideas what's going on? Broken Window test.planFetching info... Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 6, 2014 Share Posted May 6, 2014 3D Warehouse objects are free, they are not culled by any quality control, anywhere. The window you downloaded and used is poorly made, that is all there is to say other than "you get what you pay for". Some symbols from 3D Warehouse are well made and some are not relative to use in Chief Architect Software, that is all you are up against. DJP Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 6, 2014 Share Posted May 6, 2014 Check the materials. It looks like the glass material of the one you imported may have over ridden an existing material in your plan. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted May 10, 2014 Author Share Posted May 10, 2014 On 5/6/2014 at 3:05 PM, DavidJPotter said: 3D Warehouse objects are free, they are not culled by any quality control, anywhere. The window you downloaded and used is poorly made, that is all there is to say other than "you get what you pay for". Some symbols from 3D Warehouse are well made and some are not relative to use in Chief Architect Software, that is all you are up against. DJP Hi Ho David. I appreciate the time honored concept of GIGO (garbage in, garbage out) and there seems to be an ongoing debate about the value of much imported 3D content. Given that I usually pass right over about 95% of what I find online, I guess my question is how does one tell the potential quality a downloaded object relative to its use in Chief Architect? Is there something I should be looking for or is it simply a matter of trial and error? Link to comment Share on other sites More sharing options...
