new wall not showing texture
Dennis_Gavin
 copied a stucco wall, renamed it, changed attributes, using James Hardie exterior plank
and have it selected. BUT it does not show up.  It stays stucco.  I can post the plan but want to see
if this is still a residual problem from the previous new wall type problem. Input please
The room material is for the inside of the wall.  It is the default drywall.  I did not paint anything.
Try drawing a exterior wall. Open the dbx, go to wall type and copy and then rename and change the exterior material
and see if it changes.  I bet it doesn't.  I think the COPY function somehow overrides the change in exterior wall material.
There is an Exterior Room - essentially it's a "virtual" space around the perimeter of the exterior walls and it's used to define Wall Coverings and Materials. Click just outside any exterior wall (you may need to tab through the selection) and it will highlight. Open up the dbx and you can adjust the material to Use Default.
Wall materials are a little unique in that they can be controlled by EITHER the wall definition or the room definition... but not both. Not at my computer to verify exactly where it is, but if you open the room dialog box, click on the material tab, and then double-click the material you want to change you should have an option down near the bottom that says "use default material" or something like that. Check that box.
Painting walls works a little differently in X8 than it used to, but depending on which mode you are in if you use the spray can it can change the material for all the walls in that particular room. When it does that, it does not change the actual wall material...only what you see in 3-D. That material change is recorded in the room definition and not the wall definition.
