Chris50 Posted March 10, 2016 Share Posted March 10, 2016 What in the world would cause the floor to be missing in 3d??? I am using x7 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 10, 2016 Share Posted March 10, 2016 You are probably using a FLOOR camera went what you need to be using is a FULL camera Link to comment Share on other sites More sharing options...
Chris50 Posted March 10, 2016 Author Share Posted March 10, 2016 No, I am using a prospective full overview camera that I have used thousands of times. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 10, 2016 Share Posted March 10, 2016 Post the Plan..................................... Maybe a tornado took the second floor off 1 Link to comment Share on other sites More sharing options...
Chris50 Posted March 10, 2016 Author Share Posted March 10, 2016 Have not done this forever. How do I upload the file. Link to comment Share on other sites More sharing options...
Chris50 Posted March 10, 2016 Author Share Posted March 10, 2016 It is the main level floor. The tornado would have to have taken the floor and left the house. I have seen lots of tornados here but not that one yet. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 10, 2016 Share Posted March 10, 2016 Close the Plan Zip the Plan -select "More Reply Options" -select "Browse" to the zipped file -after finding the and opening it -select "Attach This File" Add Reply Link to comment Share on other sites More sharing options...
Chris50 Posted March 10, 2016 Author Share Posted March 10, 2016 Here it is, I hope. Missing Floor Plan.plan Link to comment Share on other sites More sharing options...
rlackore Posted March 10, 2016 Share Posted March 10, 2016 Easy answer is that there isn't a second floor, or a roof for that matter. Link to comment Share on other sites More sharing options...
Chris50 Posted March 10, 2016 Author Share Posted March 10, 2016 There is no second floor. It is just not showing the floor between the foundation and the main level. Link to comment Share on other sites More sharing options...
rlackore Posted March 10, 2016 Share Posted March 10, 2016 There is no second floor. It is just not showing the floor between the foundation and the main level. Oh, that old problem. I know someone else will remember how to fix this before I do. Link to comment Share on other sites More sharing options...
rlackore Posted March 10, 2016 Share Posted March 10, 2016 I did a forum search, and Glen Woodward had the answer: "The blank floor areas are usually caused by the Build Platform To setting in the wall def dbx. There should be no reason why you can't use that wall def, as long as the above settIng is set to the correct wall layer." Change the setting to layer 5 (you're main layer): Link to comment Share on other sites More sharing options...
Chris50 Posted March 10, 2016 Author Share Posted March 10, 2016 Thank you so much, this was driving me crazy, so simple. thanks a million rlackore Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 10, 2016 Share Posted March 10, 2016 It is the main level floor. The tornado would have to have taken the floor and left the house. I have seen lots of tornados here but not that one yet. OK, I thought you were saying the 2nd Floor was missing, not the Walls surrounding the 1st Floor Structure. You need to delete the Foundation and rebuild it with the "Hang 1st Floor Platform Inside Foundation Walls" CHECKED Link to comment Share on other sites More sharing options...
rlackore Posted March 10, 2016 Share Posted March 10, 2016 OK, I thought you were saying the 2nd Floor was missing, not the Walls surrounding the 1st Floor Structure. You need to delete the Foundation and rebuild it with the "Hang 1st Floor Platform Inside Foundation Walls" CHECKED Joe, I think he's planning on bearing the floor joists on a plate. Here's a section thru his plan: Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 10, 2016 Share Posted March 10, 2016 OK, so it's the "Build Platform to" setting as you posted. I never get that wrong because I always have it set to the "Main Layer" Link to comment Share on other sites More sharing options...
