Adam_Gibson
Angled Wall Connections
 Anyone have a suggestion on how to get Chief from clipping this little angled wall back? The "Right" image is drawn with CAD fill, but obviously it won't look like that in a rendering unless I add P solids as a workaround. Am I missing something?
Have you tried messing around with the wall intersection tool? Maybe you could post the plan.
Not at my computer right now, but have you tried putting a break in that adjacent wall, chmaging the wall type for half of that wall section and then dragging it over to where you want it?
Reverse the wall Layer so that the main layer is to the outside of the shower.  Then you can turn the corner.
I just got back to the office.  Opened your plan and simply used the little diamond shaped edit handle (not really sure what that thing is called) to drag a new wall section around the corner and it worked perfectly.  Didn't reverse layers or anything.
    27611
    ChiefAKBuilder
    ChiefAKBuilder
