SierraHomes
I use the browser library once, and when I went back use it again there was no chief core, chief bonus and manufacture. The names are there but no way to open a little arrow in front is missing. I must've clicked something when I closed it. Does anyone know how to turn it on? I am working in chief X6. Any help is appreciated.
Thank all of you for your help. I need to delete older chiefs that are still on this computer is every time I go use your instructions it tries to open X2 so I need to delete that. I will try that tomorrow because my wife says it's time for dinner. Thank all of you again.
Randy
There shouldn't be any need to download the libraries.
It is probably your library filter.
Open the Library dbx.
In the Active Filter drop down, select Not Filtered. You have probably changed it to Filter at some stage.
That should fix it.
While you are there, you could clean things up by going into the filter and make sure all the libraries are unchecked - that is assuming that you don't need to use a filter.
