ArchieD Posted February 13, 2016 Share Posted February 13, 2016 Thought I was sailing towards the finish after my 2 week self-imposed crash course in HD Pro, but I have a hole in my roof. Pretty sure it has something to do with my mishandling of an interior vaulted ceiling. If anyone would have the time to take a look, I would be grateful (understatement). RUPCICH 2nd FLOOR LAYOUT.plan Link to comment Share on other sites More sharing options...
Gawdzira Posted February 13, 2016 Share Posted February 13, 2016 Is this an HD file or a Chief Architect Premier file? You are posting in the Premier forum. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 13, 2016 Share Posted February 13, 2016 Yeah, definitely post over on the other forum, but for whatever its worth, that roof seems buggy to me. I actually couldn't figure out how to fix it using auto build. Auto roofs are building that roof all wrong for some reason. Only way I could make it work was to do some of the roof manually. Link to comment Share on other sites More sharing options...
DakotaContractor Posted February 13, 2016 Share Posted February 13, 2016 Same I had to manually edit the roof planes. Will let you know on a side note however that a few of your built in cabinets in the top right of the master closet are taller than your ceiling is in that room. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 14, 2016 Share Posted February 14, 2016 Here is a You Tube video of me fixing your file in Home Designer Pro 2016 (file is attached below). https://youtu.be/5H10ONEvpyY DJP RUPCICH 2nd FLOOR LAYOUT.zip Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 14, 2016 Share Posted February 14, 2016 Nice catch Eric. Not sure if you realize why your solution works or not, but... Problem is that the wall on the lower left was drawn at a slight off angle. Open that wall and simply change the angle to 180 degrees and you're good to go. No need to delete it or drag the other wall over. Link to comment Share on other sites More sharing options...
ArchieD Posted February 17, 2016 Author Share Posted February 17, 2016 Just wanted to let you know that I opened that wall, changed it to 180 and it now has a beautiful roof--no hole. Thanks Michael. And yes, I'm using HD, so I'll join the correct forum....thanks for that too. By far the best part about this software is this forum....you guys have helped solve my worst headaches. Link to comment Share on other sites More sharing options...
