Inkscape
BethVanDeusen
I posted earlier about converting a Sketchup plan to CA. The person who claims this can be done says using Inkscape will allow me to take the plan, put it in Chief, and edit it. I'm assuming this only works in 2D. Also I am not technologically savvy like many of you so use small words and simple explanations. Or just tell me it's easier to redraw the plan in Chief instead of messing with this other program.
You don't need Inkscape, do a top view in sketchup, add one longest dimension so you have a gude and export as JPEG (it will look something like the picture #1 attached) and drop that image into Chief. Use point to point tool over that dimension in CA and do point to point over 70'8  and I have  31'11".( follow steps in image #2)  Now when you trace over that dimension ( 70'8) your wall will be the same length. Now you can trace over that plan (image #3)
