3 stud corners in framing plan, version 10
rwwood
When I display wall framing, there are no studs in the corners where exterior walls meet, rather the corner is essentially empty with the last stud on each of the two walls being that which would support sheetrock on the inside surfaces. In other words, building the walls as shown would mean that the sheathing would have no support for the last 5 1/2" on the corners (assuming a 2x6 wall). I would like to show a standard 3 stud corner and wouldn't mind having to draw it manually, but I haven't been able to figure out how.
Thanks or your help.
