Tube Steel Structures
basilbabaa
How can I create wall types and rafters types to enable me to layout carports from Tube Steel and Metal?
Like these: (See Attached)
I am trying to create walls and rafters @ 12 Gauge 2.25" tubular steel 4' OC.  But cannot seem to get the process as I am unfamiliar with how to do and best approach.
Thanks for any suggestions and any detail offer-able, as I am new to this.
Posts & Rafters can be Steel-Box (ie: Steel Tubes).
Check the Defaults for Framing.  You can specify the Type for Rafters in the Roof Structure Definition.
I was just noticing that the 2D floor plan graphic doesn't match the selection.  Is there a way to make the FP match the type?
