timmy123 Posted April 22, 2014 Share Posted April 22, 2014 Hello, I am looking for a corner frame less window in my design. However, I cannot find it in the library, can some one please post it? http://www.marvin.com/windows/specialty-windows-corner-window/ http://www.houzz.com/photos/68221/Shirley-Avenue-modern-hall-san-francisco Link to comment Share on other sites More sharing options...
Rich_Winsor Posted April 22, 2014 Share Posted April 22, 2014 What's better than a 90° Corner Window? How about four 90° Corner Windows. Here's a little concept that came about while exploring a HomeTalk thread about butt glazed corner windows. Link to comment Share on other sites More sharing options...
timmy123 Posted April 22, 2014 Author Share Posted April 22, 2014 Hi Rich, I tried the directions from the hometalk forum. but I am not sure how to create the top part using soffits can you elaborate a little bit? Link to comment Share on other sites More sharing options...
Rich_Winsor Posted April 23, 2014 Share Posted April 23, 2014 Hey Timmy, here's the deal. I was using soffits because I was working with Home Designer Pro. With CA its easier because you can use Polyline Solids for the upper walls. Start out by drawing Pony Walls where you want the glass to be. In the "Wall Specification" dbx go to the "Wall Types" tab and define the Lower Wall Type you want to use and set the height of the lower wall. For the upper wall type choose "Glass Shower". This will give you the lower wall with glass on top. To build the upper portions of the walls above the glass go to your plan view and draw a Rectangular Polyline over the Pony Walls. Convert the Polyline to a Polyline Solid and set the pertinent values in the "3D Box Specification" dbx. to match the length and thickness of the Pony Wall below and set a height for the upper Polyline Solid wall section. With a little tweaking you should be able to get the desired effect. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 23, 2014 Share Posted April 23, 2014 Do a search in the Legacy Forum. There are some threads there that deal with this, without needing Polyline Solids or Soffits. Link to comment Share on other sites More sharing options...
dshall Posted April 23, 2014 Share Posted April 23, 2014 Do a search in the Legacy Forum. There are some threads there that deal with this, without needing Polyline Solids or Soffits. Joe is correct, seArch CORNER WINDOWS VIDEOS BY DSH, that should get you a video on a method that we all worked on a couple years ago. Link to comment Share on other sites More sharing options...
