brushpark Posted December 18, 2015 Share Posted December 18, 2015 I have a two story staircase which lands on a slight angle to the second floor. Is there a way to align the last step to reach the loft? Working with Chief X7 and hope to find a solution. Thanks all! Tom Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 18, 2015 Share Posted December 18, 2015 For the sake of easier modeling, in order to avoid violating most stair codes, and to accomplish a more interesting look IMO, I would simply reshape that upper section of floor where the stairs terminate to accommodate the stair angle. It would meet code, would be more functional and would draw deliberate attention to what may otherwise look like a mistake or shawdy design/craftsmanship. Link to comment Share on other sites More sharing options...
Gawdzira Posted December 18, 2015 Share Posted December 18, 2015 If you have to crash that stair in at that angle use a landing which you can shape for the last tread. Link to comment Share on other sites More sharing options...
brushpark Posted December 18, 2015 Author Share Posted December 18, 2015 The home is a 6,000 square ft. new design that will be very contempory with a sculptured staircase in metal and glass. This stair will fit into a full glass atrium and will for just fine with the local codes, no different than a circular staircase with the treads having a center width that would meet code. I have created a quick visual with my stair problem and didn't post the actual plan. There will be two runs and I have been asked to create a 3d visual and raytrace this. I did try the landing, but the rail didn't continue up to the top level. Thanks for your input. Link to comment Share on other sites More sharing options...
joey_martin Posted December 18, 2015 Share Posted December 18, 2015 Even a circular staircase would have to have to faces that meet at the top for connection. Either make a small section of the upper area perpendicular, or as others have said, use the landing tool for the last step and make the connection. Link to comment Share on other sites More sharing options...
