Line showing through exterior in elevation view.
HaywardVT
I can't figure out why this line is here, or what it represents. It only shows up in this view and sometimes while rotating the camera in 3D orthographic. I think it has something to do with where the floors meet, or maybe the lines that show the exterior material don't recognize that it's the same between floors and won't combine into one surface, but I'm not sure why that would happen on this wall and not the others.
Johnson Lot 43.plan
Is it some thing like this? I am afraid to state the obvious.
Bye the way, you remind me about a joke, two guys sitting in a bus side by side, one asked the other "wa.....waaa....what ..t....t..time is it rrrright now" the other guy kept silent. Again the guy repeated questioning, asked several times and the guy is not talking at all. So some one else following the two, answered him "10:30". After one minute the silent guy getting close to the other whispered, saying "mmm.....mm..my ffffffriend I was af...fff...afraid you woulddd tttakkke it I wassss... making fun of youuuu." So obviously both had the same tongue problem, like you and me( English is my 99th language) no worries. Just say what you want, some one will understand and interpret to others, like they do it for me some times.
Don't ask me why but I moved the wall upstairs with the extraneous line and then moved it back. The line went away. It is possible the wall was slightly offset.
I zoomed in and out,  then a back clipped cross section,    kicked the cat and spit on the dog,  and it was fixed.
I tried moving the walls out of position and back again, it fixed a similar problem I had before but it's not working this time.
I don't know what the difference is between the backclipped cross section and cross section/elevation, but in the backclipped view I can only see the line causing the issue and can't select it. I'm not sure what to do now.
I see lines like that from time to time on my plans, even when the walls are perfectly aligned. I think there might be a bug there. Sometimes just selecting the wall and opening the dbx and closing it will make the unwanted line go away, sometimes not. Very hit and miss. And sometimes the line is there in vector view, but when you send the view to layout, it goes away. When it doesn't, I usually just end up using 'Edit Layout Lines' to delete it.
