Joe_Carrick Posted November 5, 2015 Share Posted November 5, 2015 If you want a monolithic Tub Surround (sides and top all the same material), you can just place a thick Custom Countertop that sits on the floor. You don't need a Cabinet. Link to comment Share on other sites More sharing options...
dshall Posted November 5, 2015 Share Posted November 5, 2015 If you want a monolithic Tub Surround (sides and top all the same material), you can just place a thick Custom Countertop that sits on the floor. You don't need a Cabinet. Joe, the drop in tubs are a mystery to me. I hear what you are saying, however, I just tried to put in DROP IN TUBS in both countertops and cabinets bases, neither worked well. It seems to me at one time using a DROP IN TUB in a base cabinet worked, but the problem with this is the base is never a nice simple rectangle. I use a psolid with hole to create the tub surround. Works good, but would be better if I could use a countertop and drop in the tub whereby the HOLE will be created auto. So the question is, what tubs are you using to drop into a custom countertop that will then create the auto hole for tub? Can you post a quick plan showing a tub dropped into a custom countertop? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 5, 2015 Author Share Posted November 5, 2015 OK Scott, Here's a Plan. I had to place this particular tub free standing and edit it to "Insert in Countertop". Then I just moved it into the 20 1/2" thick Countertop. I set the Countertop thickness as 20.5" because the tub is 21" tall. Tub in Custom Countertop.zip Link to comment Share on other sites More sharing options...
dshall Posted November 5, 2015 Share Posted November 5, 2015 OK Scott, Here's a Plan. I had to place this particular tub free standing and edit it to "Insert in Countertop". Then I just moved it into the 20 1/2" thick Countertop. I set the Countertop thickness as 20.5" because the tub is 21" tall. That is great, thank Joe. I got it now. The key is to change the symbol options to INSERT IN COUNTERTOP. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 5, 2015 Share Posted November 5, 2015 I hope I can remember this next time I do this, big time saver. Maybe I should make one and save it to the lib. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 5, 2015 Author Share Posted November 5, 2015 You may need to create a Rectangular Slab with a hole in it to match your Tub. That needs to be a part of the symbol and it needs to be identified as "Countertop". Chief always cuts a rectangular hole in the countertop matching the overal size of the symbol. It uses the material name "Countertop" so that it matches the Countertop material. Link to comment Share on other sites More sharing options...
dshall Posted November 5, 2015 Share Posted November 5, 2015 .....Chief always cuts a rectangular hole in the countertop matching the overal size of the symbol...... not true Joe, note the OVAL CUTOUT, good info Joe. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 5, 2015 Author Share Posted November 5, 2015 Scott, That's the hole in the "Slab" which should be slightly smaller than the Tub. Then it depends on the Top of the Countertop and the Height of the Tub being equivalent. Chief makes the "Slab" height match the "Countertop" height. These things can be adjusted in the dbx for each object. This is the same thing that happens with oval sinks. It should also be noted that if there's a Base Cabinet (0 height and 0 toe-kick height) then the Symbol will automatically match that but you have to get the countertop thickness set to match the overall cabinet height. That's just another way of getting to about the same place. Link to comment Share on other sites More sharing options...
dshall Posted November 5, 2015 Share Posted November 5, 2015 JC's tub drop in tub video Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 5, 2015 Author Share Posted November 5, 2015 Scott, You don't have to change the height to cut/relocate the hole. Just grab an edge of the countertop and move it. IOW, any edit of the countertop itself will do the job. Or, just "Rebuild 3D" Link to comment Share on other sites More sharing options...
CAmichael240114 Posted November 5, 2015 Share Posted November 5, 2015 This is a drop-in bath with a built-up tile surround done with a poly solid Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted November 6, 2015 Share Posted November 6, 2015 I like using a base cabinet in most circumstances. Can change the material to whatever or have panels etc. No need to create separate slab for "cabinet" area. Whatever works best for the situation. Link to comment Share on other sites More sharing options...
hammock_monk Posted January 9, 2024 Share Posted January 9, 2024 Sorry to revive an old thread, but I was directed here from a later, similar one. I am also having trouble with my tub cutting a rectangular hole in the countertop. I've tried matcing cabinet and/or countertop heights to the tub height but without success. Would someone walk me through the process? Plan: https://drive.google.com/file/d/1z2MkbMRJtGiBEEGSICXOcaQm_KcTKH_R/view?usp=drive_link Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 9, 2024 Author Share Posted January 9, 2024 Go back and read this entire thread. You will need the tub symbol to include a rectangular countertop with a hole that matches the shape of the tub. 1 Link to comment Share on other sites More sharing options...
hammock_monk Posted January 9, 2024 Share Posted January 9, 2024 Joe, thanks for the input. I had already read the entire thread. I did not understand your additional comment but I did accomplish what I needed to do by studying this video: https://www.facebook.com/watch/?v=544395256650461 Thanks again for trying to help me out. hm Link to comment Share on other sites More sharing options...
