ROOF EXPERTS
Sweeney
Hello all,
Trying to accomplish the attached detail for rafter tails.  Any and all recommendations will help.
I have been messing around with sub-fascias and overhang sizes, trying to learn how Chief "thinks" but coming up short
Thanks as always
Austin
P.S. The roof is 16-12
Thompson.plan
Austin,
I pulled back the overhang, and adjusted the baseline height, made sure to rebuild framing.
I had to mess around a little to get this, you may need to do the same.
Edit: You might have to rebuild roofs again to get the birds mouth correct...I'm not sure if there is a way after the fact. Also, change the room type exterior to the knee wall to "Attic"
Mike illustrates what I often point out and that is that software does not "think". It is preprogrammed but in the end is merely a mechanical device that the end user operates through settings and procedures to obtain a result. It is then a matter of study and practice to then master the tool that is Chief Architect Premier.
Austin,
Nice work Mike.
    31608
    FireflyHomes
    FireflyHomes
