Rich_Winsor Posted October 2, 2015 Share Posted October 2, 2015 If you have made the mistake of trying to use Chief to save a large plan file to a USB flash drive you already know what a time consuming process that can be. I don't know what the data transfer rate is for doing a "save as" from Chief's File drop down menu, but it is way slower than the transfer rate for using Windows Explorer to make the transfer. By way of a test I tried saving a 71.9MB plan file to my USB flash drive using Chief's save as function. The little teal whirligig sat there and spun for an agonizing 4 minutes and 50 seconds before the save was completed. By way of comparison transferring the same file from my desktop to the USB drive using Windows Explorer took only 29 seconds. So bottom line, it will save you a lot of time to save your file from Chief to some convenient location on your hard drive and then transfer the file to your USB flash drive using Windows Explorer. But then you probably already knew that. Link to comment Share on other sites More sharing options...
Doug_Park Posted October 2, 2015 Share Posted October 2, 2015 Under normal circumstances, Chief should recognize that the USB device is ejectable and then do a save to a temporary location and a copy to the USB device. This should then approach the speed of copying using Windows Explorer. Some USB devices are horribly slow when doing random access IO, which we rely on to write recovery markers into our files so that minor file corruption doesn't always result in total loss of your data. This won't work if your temporary files folder is also located on an ejectable device. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 2, 2015 Share Posted October 2, 2015 If you have made the mistake of trying to use Chief to save a large plan file to a USB flash drive you already know what a time consuming process that can be. I don't know what the data transfer rate is for doing a "save as" from Chief's File drop down menu, but it is way slower than the transfer rate for using Windows Explorer to make the transfer. By way of a test I tried saving a 71.9MB plan file to my USB flash drive using Chief's save as function. The little teal whirligig sat there and spun for an agonizing 4 minutes and 50 seconds before the save was completed. By way of comparison transferring the same file from my desktop to the USB drive using Windows Explorer took only 29 seconds. So bottom line, it will save you a lot of time to save your file from Chief to some convenient location on your hard drive and then transfer the file to your USB flash drive using Windows Explorer. But then you probably already knew that. Appreciate the heads up Rich. I personally don't seem to have that problem though. I'm wondering if perhaps its specific to certain devices or systems. Doing a save as and using Windows Explorer seem to result in a nearly identical speed of data transfer for me. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 2, 2015 Share Posted October 2, 2015 I would think it might be dependent on the USB. Older ports didn't have nearly the speed of newer ones. There might also be a restriction depending on the anti-virus settings. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted October 3, 2015 Author Share Posted October 3, 2015 Well shut my mouth wide open (whatever that means). Upon further review it appears as though the transfer speed for USB flash drives is indeed very much device dependent. While all my flash drives are USB 3.0 and they are all being plugged into an Intel USB 3.0 Root Hub there is quite a difference in performance from drive to drive. The drive that performed so poorly is an older one that has been beating around in my pocket so long that there are no identifiable markings on it any more. Windows says it is a Cruzer 8GB drive. I also tried the "save as" on an 8GB Transcend drive that took about 20 seconds and finally I did a "save as" to a spiffy SanDisk 64GB Extreme flash drive that lived up to its name by being almost instantaneous in completing the save (no more than 2 or 3 seconds). So I guess I should amend the tip to say that if you have a dog slow USB drive you can save yourself some time by using the Windows Explorer option. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 3, 2015 Share Posted October 3, 2015 ...So I guess I should amend the tip to say that if you have a dog slow USB drive you can save yourself some time by using the Windows Explorer option. Good tip! Link to comment Share on other sites More sharing options...
keithhe Posted December 30, 2015 Share Posted December 30, 2015 I have stopped using virtually all external devices for file transfer. Nearly anything I need to transfer, regardless of size, I use TeamViewer that has an awesome file transfer feature, among many others. I regularly move items between my computers within my LAN, and over the WAN to other computers. Very easy, very fast. Particularly within your LAN, most of us are on Gb speeds, so you can move a lot, fast. Not just files, you can move a folder or as many folders as you want, all at once. Link to comment Share on other sites More sharing options...
