Tomathome Posted September 28, 2015 Share Posted September 28, 2015 I am designing a home that has different a different roof color on part of the house. I can't find a way to make this happen. I have tried the material painter, but that does not work. Any suggestions would be appreciated. Thanks Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 28, 2015 Share Posted September 28, 2015 select a roof plane, open the dbx and edit the material. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 28, 2015 Share Posted September 28, 2015 Create/copy a new roof material and apply to the areas you want a different color. Link to comment Share on other sites More sharing options...
WendyatArtform Posted September 28, 2015 Share Posted September 28, 2015 If material painter is not working, you probably have wrong setting. After you select the painter, look at bottom of screen and make sure "C" for Component is the active choice Link to comment Share on other sites More sharing options...
HumbleChief Posted September 28, 2015 Share Posted September 28, 2015 Curious. How do you select another roof material with the material painter if you don't have another roof material defined that you can select? Link to comment Share on other sites More sharing options...
glennw Posted September 29, 2015 Share Posted September 29, 2015 Curious. How do you select another roof material with the material painter if you don't have another roof material defined that you can select? Larry, The Material Painter opens up the library for material choice. The Material Eyedropper requires you to select an existing on screen material. Link to comment Share on other sites More sharing options...
Tomathome Posted September 29, 2015 Author Share Posted September 29, 2015 Thank you for the ideas. I had to change the material painter to "component" and was able to make the change. Link to comment Share on other sites More sharing options...
