buzzsaw204 Posted September 10, 2015 Share Posted September 10, 2015 hi, i've created a few custom linetypes, by trial-error, to get the right TL-scale i needed. now i have all these LT created and dont want. where do i go to delete them?? Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 10, 2015 Share Posted September 10, 2015 When you create a new line style it then appears in your Library Browser in the "User Catalog" area where it can be renamed or deleted. DJP Link to comment Share on other sites More sharing options...
buzzsaw204 Posted September 10, 2015 Author Share Posted September 10, 2015 When you create a new line style it then appears in your Library Browser in the "User Catalog" area where it can be renamed or deleted. DJP yes, i created and do see it. it's in "appears in your Library Browser in the "User Catalog" area" and i have deleted it in here. but is still appears in the LT in the drawing. i want to PURGE it in the drawing. Link to comment Share on other sites More sharing options...
Ginkgohouse Posted September 10, 2015 Share Posted September 10, 2015 If you delete it from the library, save and close the plan, then open the plan again the custom line style will not appear in the line DBX. it worked for me anyway. Link to comment Share on other sites More sharing options...
buzzsaw204 Posted September 10, 2015 Author Share Posted September 10, 2015 If you delete it from the library, save and close the plan, then open the plan again the custom line style will not appear in the line DBX. it worked for me anyway. not for me. still in the Line dbx Link to comment Share on other sites More sharing options...
Ginkgohouse Posted September 10, 2015 Share Posted September 10, 2015 Are their any lines in the plan utilizing the line style? When I created the unique line style and applied it to a line and then deleted it from the library, It would still appear in the DBX. Once i deleted all of the lines in the plan, closed CA and reopened the unique was no longer in the DBX. I will say it is a pretty tricky ! Link to comment Share on other sites More sharing options...
buzzsaw204 Posted September 10, 2015 Author Share Posted September 10, 2015 Are their any lines in the plan utilizing the line style? When I created the unique line style and applied it to a line and then deleted it from the library, It would still appear in the DBX. Once i deleted all of the lines in the plan, closed CA and reopened the unique was no longer in the DBX. I will say it is a pretty tricky ! yes. i do realized that if a linetype is used in the plan, then it can not be purge out the dbx. but i have tested that. deleted that unique linetype in the User Catalog, and delete all used line in the plan. then Save, close and reopen...but is show in dbx Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 10, 2015 Share Posted September 10, 2015 Did you close Chief? I think the line styles are kind of residual until Chief itself is closed and restarted. Link to comment Share on other sites More sharing options...
