jessde Posted August 25, 2015 Share Posted August 25, 2015 X7 There is some detail missing and incomplete lines in my line drawings. is this normal? I tried drawing in the incomplete lines but then it is an obvious attempt to fix with the added lines being crisp and dark. Any remedy for this ? Am I missing something here or is this something we just have to live with? Thanks for any comments. Link to comment Share on other sites More sharing options...
rlackore Posted August 25, 2015 Share Posted August 25, 2015 Please post the plan and screenshots showing what you are describing, then we may be able to help. Link to comment Share on other sites More sharing options...
jessde Posted August 28, 2015 Author Share Posted August 28, 2015 Ok here's a view. I also spoke with someone who suggested it may be that my graphics card is not up to it. It is , I believe a Radeon 4200.I have recently updated the driver. thanksguest cottage LD.plan Link to comment Share on other sites More sharing options...
ShaneK Posted August 28, 2015 Share Posted August 28, 2015 Just downloaded and no lines missing on floor plans or 3d. Edit: elevation #5 has issues and might be causing problems with your graphics card. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 28, 2015 Share Posted August 28, 2015 Can you post a screenshot showing the "missing lines"? I suspect whats going on is that you're not getting lines that YOU believe should be there but that Chief will never draw. Its a little difficult for me to fully describe, and I don't understand all of it, however Chief seems to use PATTERN settings for many of its lines (which may not look like the TEXTURE), and edges for the rest. It will not draw a line where a true edge does not exist. For example, where 2 objects on 2 different planes occupy the same space...that inside edge won't draw even though you know its there. To get that edge line to draw, you need to make sure one or both objects actually have an exposed edge at that location. There are also some complex shapes that will have no lines show up because there is no specific edge to draw. Link to comment Share on other sites More sharing options...
ShaneK Posted August 28, 2015 Share Posted August 28, 2015 Floor plan & 3d Edit: Elevation #6 & 7 are vector view; #5 is a line drawing and #6 is a technical drawing. I changed #5 to a different type drawing and it behaved. Link to comment Share on other sites More sharing options...
ShaneK Posted August 28, 2015 Share Posted August 28, 2015 See if this opens for you. guest cottage LD.plan Link to comment Share on other sites More sharing options...
jessde Posted August 29, 2015 Author Share Posted August 29, 2015 Ok I sent the wrong view but this will work to show what I need. I tried different renderings to compare each. If you look at the south elevation ,which is a line drawing ,you can see the incomplete lines and detail. The most obvious is the west side upper windows area. the west wall where the windows are placed is curved which may be part of the issue. If you compare it to the north elevation, a technical drawing, you will see the lines in this area clearly. I'm just checking out the different renderings and may never use a line drawing but I'd like to understand the character of each. As I continue to learn this program I'm often confronted with things that don't act or display like I would expect. Most often I find that I'm not doing something correctly or my system is not up to the task. Thanks to all who are helping me to clarify this. Link to comment Share on other sites More sharing options...
rlackore Posted August 31, 2015 Share Posted August 31, 2015 I don't see any obvious "missing line" issues in either plan or your saved elevations. BTW, did you mean to include a plan or image in your post #8? Link to comment Share on other sites More sharing options...
jessde Posted August 31, 2015 Author Share Posted August 31, 2015 No I did not send another image , I thought the first would be adequate to see how views compared. It seems that what I'm hearing is that no one else is seeing the missing lines and details as I am. Could it be my graphics card as one person suggested? Link to comment Share on other sites More sharing options...
rlackore Posted August 31, 2015 Share Posted August 31, 2015 Okay, I see the problem with the upper-left area on the line drawing. I suspect it's a problem with Chief not handling the curvature of the wall/windows very well. Probably not a video card issue. Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted August 31, 2015 Solution Share Posted August 31, 2015 I agree. Not a video card issue. It looks like one of the issues I described in my post above. Chief won't draw lines where an EDGE does not exist. This is an issue I really think needs to be fixed and something that should probably be added to the suggestion section. Link to comment Share on other sites More sharing options...
jessde Posted September 1, 2015 Author Share Posted September 1, 2015 I agree. Not a video card issue. It looks like one of the issues I described in my post above. Chief won't draw lines where an EDGE does not exist. This is an issue I really think needs to be fixed and something that should probably be added to the suggestion section. Ok , I tried the line drawing view on another computer with better graphics and found no significant improvement. I assume that you and Robert are correct and I should contact CA . thank you all for your help. Jess Link to comment Share on other sites More sharing options...
