Ray626 Posted August 16, 2015 Share Posted August 16, 2015 I just purchased a new laptop with windows 8.1. I have older version Chief Architect X2 Lite is there any way to load it into 8.1 without spending $1,500 for newer version? Chief Architect states that it can be done it just won't be supported. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 16, 2015 Share Posted August 16, 2015 Did you try installing it ? you may need to set it's compatibility mode to Windows 7 or even XP , and perhaps set it to run as Administrator as well but worth a try. the other option is to do a Dual boot on your new computer and install x2 on the other OS Your new computer will get Win10 anyday too of course Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 16, 2015 Share Posted August 16, 2015 My X2 runs fine in Windows 7 and 10, it should run fine in Windows 8 as well. DJP Link to comment Share on other sites More sharing options...
Ray626 Posted August 16, 2015 Author Share Posted August 16, 2015 On 8/16/2015 at 3:24 AM, DavidJPotter said: My X2 runs fine in Windows 7 and 10, it should run fine in Windows 8 as well. DJP I have it in my downloads but how do I load it on to computer. My computer asks which app to use and or program. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 16, 2015 Share Posted August 16, 2015 where did you download it from? your Digital Locker at CA ? the file should just Run when you double click on it , however you want to be sure you trust the source of that file 100% before doing so , and have you CD Key ready. M. Link to comment Share on other sites More sharing options...
Ray626 Posted August 16, 2015 Author Share Posted August 16, 2015 On 8/16/2015 at 5:14 AM, Kbird1 said: where did you download it from? your Digital Locker at CA ? the file should just Run when you double click on it , however you want to be sure you trust the source of that file 100% before doing so , and have you CD Key ready. M. I downloaded from the digital locker. when I double click on it my windows 8.1 asks (How do I want to open this type of file) . I have loaded it on to my windows 7 before with no problems Yes I have CD key ready to go Link to comment Share on other sites More sharing options...
Kbird1 Posted August 16, 2015 Share Posted August 16, 2015 right click on the file > properties> and make sure Win8.1 hasn't Locked the file , which it does if it comes from the internet and "thinks" it is an "unsafe" file type, ie it has an .exe extension, there will be a check box if it is locked . Not sure what the extension is but it is likely .exe or .msi , both of which are programs and they should just "run" they don't need another Program to run. have you done all your Win8 Windows updates? , the Windows Installer Program may need an update ? M. Link to comment Share on other sites More sharing options...
Ray626 Posted August 17, 2015 Author Share Posted August 17, 2015 appreciate help. got to work. Will take advise. to busy to spend time on computer Link to comment Share on other sites More sharing options...
Ray626 Posted August 18, 2015 Author Share Posted August 18, 2015 still can not get file to open. every time I click on download all it says is ( How do you want to open this type of file (.41[1])? ) And asks Look for an app in the store It is in down loads as Chief Architect_Lite_Setup-12.2.1.41[1] Type 41[1] File if this means anything Link to comment Share on other sites More sharing options...
Dan_Park Posted August 18, 2015 Share Posted August 18, 2015 It appears you have some sort of anti virus protecting you. Try changing the name to Chief Architect_Lite_Setup-12.2.1.exe Link to comment Share on other sites More sharing options...
Solution Ray626 Posted August 18, 2015 Author Solution Share Posted August 18, 2015 On 8/18/2015 at 4:55 PM, Dan_Park said: It appears you have some sort of anti virus protecting you. Try changing the name to Chief Architect_Lite_Setup-12.2.1.exe Perfect the exe took care of problem Thanks so very much for your help Link to comment Share on other sites More sharing options...
Kbird1 Posted August 18, 2015 Share Posted August 18, 2015 did you check what I said in post 7 ? depending on you security settings Windows may have locked the file as it is an executable ie .exe file either that or Norton or something has locked it for the same reason as Dan said. M. Link to comment Share on other sites More sharing options...
