tommy1 Posted August 13, 2015 Share Posted August 13, 2015 We made a material change on the roofs in one plan and when I select the roof and try to change the material for the ridge cap, most of the time I can use the keyboard to hit the first letter and it takes me to the textures starting with that letter. Well, it doesn't do that. I have to scroll down to find the texture. Many times I can do this and it works. I don't know why sometimes it works and sometimes it doesn't. Anyone notice this? Link to comment Share on other sites More sharing options...
Solution rlackore Posted August 13, 2015 Solution Share Posted August 13, 2015 I've found that if you first select any material, it sort of "activates" the dbx and then I can type to search. Link to comment Share on other sites More sharing options...
tommy1 Posted August 13, 2015 Author Share Posted August 13, 2015 Thanks. That worked. Apparently sometimes I do that and sometimes not. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 13, 2015 Share Posted August 13, 2015 Robert is correct and this is SWB (Standard Windows Behavior). Basically what is happening is that the "Tree/List" has to have focus in order to intercept the key strokes. It only gets the focus when you select something in that List. It could be possible for the program to set the focus when a Folder is expanded but that might have other consequences that might not be desired. Link to comment Share on other sites More sharing options...
rlackore Posted August 13, 2015 Share Posted August 13, 2015 Robert is correct and this is SWB (Standard Windows Behavior). The strange part is that there is a highlighted selection, which gives the impression that the dbx is "active" and ready to go. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 13, 2015 Share Posted August 13, 2015 The strange part is that there is a highlighted selection, which gives the impression that the dbx is "active" and ready to go. Yeah, but that's only because it's the initial row in the Tree List - that's a part of the setup of the "Control". There is a separate programming function to set the "Focus". Link to comment Share on other sites More sharing options...
dshall Posted August 13, 2015 Share Posted August 13, 2015 The strange part is that there is a highlighted selection, which gives the impression that the dbx is "active" and ready to go. Frustrating behavior, I wish I did not have to click to activate...... but life could be worse. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 13, 2015 Share Posted August 13, 2015 I think this is probably a "Paper Cut" classification in terms of programming. It should be just a single line of code to have the focus automatically set. Link to comment Share on other sites More sharing options...
tommy1 Posted August 13, 2015 Author Share Posted August 13, 2015 I have found that you don't even need to click on something to activate it, you can just move the scroll bar a little and it will activate it. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 13, 2015 Share Posted August 13, 2015 I have found that you don't even need to click on something to activate it, you can just move the scroll bar a little and it will activate it. That's because the scroll bar is a child control of the TreeList. When you click on the scroll bar you have set the focus to the scroll bar. However, since that only accepts navigation keys, all other keys are passed up to the parent for processing. Link to comment Share on other sites More sharing options...
