Church Steeple
mrscott
Just from a design standpoint, Steeple's typically are the same dimension each side so the roof-lines meet all in the same point.  You may have some other plan, but I wanted to at least mention this in case you've not deigned one before.
You dont need it to be the shape of your vestibule, as you can simply over-frame the perimeter into the roof area behind...in fact it would look better this way.
