mikes616 Posted June 24, 2015 Share Posted June 24, 2015 I changed the lineweight many times for both lines and the lineweights in layers but the change is not reflected in the plan. What am I doing wrong?? I have tried everything. I have a feeling it's something simple...I hope. Using X7. Thanks Mark Link to comment Share on other sites More sharing options...
Solution dshall Posted June 24, 2015 Solution Share Posted June 24, 2015 Turn on LINE WEIGHTS. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 24, 2015 Share Posted June 24, 2015 Do you have "Line Weights" turned ON? There is a Toggle Icon on the "Modes Toolbar". There's also an item in the "View Menu" Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 24, 2015 Share Posted June 24, 2015 Are your items that you are changing checked to use the layer line weights in the DBX Link to comment Share on other sites More sharing options...
mikes616 Posted June 26, 2015 Author Share Posted June 26, 2015 Thank you guys so much! I had it turned off.....don't know how that happened. Mark Link to comment Share on other sites More sharing options...
