owenplum Posted June 17, 2015 Share Posted June 17, 2015 I have a floor plan & am trying to place a camera to see the 3D view. When the camera tab open it is blank with no image, any ideas? Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted June 17, 2015 Share Posted June 17, 2015 Never heard of that before. The only thing that comes to mind is that you have a very low quality video card. Have you tried closing down and rebooting the system? One other possibility is that all the layers are turned off in 3D view. What version of Chief are you using? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 17, 2015 Share Posted June 17, 2015 Another possibility as that your camera is not facing your model or is above or below it. Link to comment Share on other sites More sharing options...
owenplum Posted June 17, 2015 Author Share Posted June 17, 2015 Camera is definitely facing the house, and is on the right level. Was thinking of a computer upgrade so may have to look into video card. Layers seem to be right in 3D view. Using X7, never had this problem in previous version. Link to comment Share on other sites More sharing options...
Kiwideziner Posted June 17, 2015 Share Posted June 17, 2015 Are you on a laptop? are you using a dedicated video card? or on board? unfortunately only guesses without a plan. Link to comment Share on other sites More sharing options...
owenplum Posted June 18, 2015 Author Share Posted June 18, 2015 NO the video card is not dedicated and yes on laptop. thinking this is probably the case, what are minimum requirements I should look for on upgrade? Link to comment Share on other sites More sharing options...
Kiwideziner Posted June 18, 2015 Share Posted June 18, 2015 A proper nvidia card at least 600 series with min 2Gb on board . Check out my signature and also others to see what is working. I have found that X7 will not run without a dedicated card, my laptop works reasonably well more than adequate for field work. Link to comment Share on other sites More sharing options...
builtright3 Posted June 18, 2015 Share Posted June 18, 2015 Was this the first time you tried the 3D on this computer or has it worked before? The reason for me asking is I have two video cards on my computer and if its not set to the right one I have the same problem. Link to comment Share on other sites More sharing options...
