MarkMc Posted February 22, 2014 Share Posted February 22, 2014 Plan started in X5. Polyline created in backclipped elevation and converted to P Solid. Does not show in floor plan or floor camers. It does show in full camera. Have checkd that the layer is correct and displayed, tried changing layer. Only happening on one plan- doesn't happen on new plans and went and checked two other legacay plans and no problem. Just wondering if I'm missing something before I send it in? In the pics I pulled it out into the aisle just to make sure I knew where it was. P-solid.zip Link to comment Share on other sites More sharing options...
glennw Posted February 22, 2014 Share Posted February 22, 2014 Mark, It is down on Level 1 floor plan. Link to comment Share on other sites More sharing options...
MarkMc Posted February 23, 2014 Author Share Posted February 23, 2014 Thanks Glenn, didn't think to look there. What I don't understand is- created on the 2nd floor, shows in elevation on the second floor (where created) and if I copy and paste it to the second floor the pasted one shows in plan and floor camera- So I copied and pasted one to the first floor. Shows up in plan-BUT neither thje original which shows in plan nor the pasted one show up on the first floor if I use the floor camera. Capture with second floor elevation showing original and copy paste, lower floor with both shown in plan Link to comment Share on other sites More sharing options...
Solution glennw Posted February 23, 2014 Solution Share Posted February 23, 2014 Mark, If you want the Polyline Solid to remain on the floor that you draw it on in Cross Section view, use the Polyline Solid tool directly. Don't convert from a Polyline to Polyline Solid. 1 Link to comment Share on other sites More sharing options...
dshall Posted February 23, 2014 Share Posted February 23, 2014 Mark, If you want the Polyline Solid to remain on the floor that you draw it on in Cross Section view, use the Polyline Solid tool directly. Don't convert from a Polyline to Polyline Solid. This is so weird. I remember this from a long time ago. As I work I almost always turn a pline to a psolid, and I know I must do it on the second floor but I don't have this problem anymore. I know what Glenn is saying is true, it's just that this has not happened to me in years. Do you think I am special or is this another sign of my nuttiest? I'll check it out tomorrow. Link to comment Share on other sites More sharing options...
MarkMc Posted February 23, 2014 Author Share Posted February 23, 2014 Got it Glenn, thanks, have to changed my habits, I'm not alowed off the first floor often so guess that's why I never ran into it. Link to comment Share on other sites More sharing options...
