Chucky843 Posted May 31, 2015 Share Posted May 31, 2015 Hi, Im having a problem with the auto dimension feature. I seem to keep getting double dimension lines and the dimension txt seems to be jumbled up. Hard to read clear measurements. What am I doing wrong? Any help would be appreciated. Link to comment Share on other sites More sharing options...
Kiwideziner Posted June 1, 2015 Share Posted June 1, 2015 I stopped using auto elevation dims as they were not working, I don't think it has been fixed yet. Auto antything can be between 10% and 100% correct. Link to comment Share on other sites More sharing options...
scottharris Posted June 1, 2015 Share Posted June 1, 2015 When I use automatic dimensions for elevations, I have a dimension default set (usually through an annotation set); the dimension default is defined to only locate a few items, and has the font size, and arrow size defined - otherwise, you will get a lot of dimensions that are difficult to read. I typically use the interior elevation with the "NKBA general annotation" and you can see how it works with the auto NKBA dimension; if the annotation set is "1/4 Scale" it looks very messy. See my two examples. The difference was the annotation set with the correct defaults define. I don't do a lot of exterior dimensions; hence my interior example. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 1, 2015 Share Posted June 1, 2015 Couple of things might help.... in your 1/4 Dimension defaults set the Auto Dim line separation to say 24" or 30 " (default is 18" I think ) and in the Auto Elevation defaults Uncheck everything on the Locate tab for a bar bones look , then add back as needed. Not sure why your stairs are picked up mine aren't in the quick test plan I did........ oh I had to use a multi select (with the shift Key) after clicking on MANUAL dimension on the dim.toolbar and delete them that way . Cabinets only on Link to comment Share on other sites More sharing options...
Chucky843 Posted June 1, 2015 Author Share Posted June 1, 2015 Thanks for the information and help. I will employ these stratagies. Link to comment Share on other sites More sharing options...
