mtldesigns Posted 23 hours ago Share Posted 23 hours ago Good evening... I know the layer control, turns the construction lines off, that's not what I am asking about. I have few elevation views that will consist of only the front stoned wall and pier post. I took a section view, looking away from the house (to the road per say), but the construction lines for the house show up. If I turned that layer off, they turn off on the true elevation views as well. The only way I can think of doing it, is to do it by removing layout lines after I drop the view.. Any idea on how to turn these off, any suggestion would be appreciated. Link to comment Share on other sites More sharing options...
JKEdmo Posted 23 hours ago Share Posted 23 hours ago 19 minutes ago, mtldesigns said: Good evening... I know the layer control, turns the construction lines off, that's not what I am asking about. I have few elevation views that will consist of only the front stoned wall and pier post. I took a section view, looking away from the house (to the road per say), but the construction lines for the house show up. If I turned that layer off, they turn off on the true elevation views as well. The only way I can think of doing it, is to do it by removing layout lines after I drop the view.. Any idea on how to turn these off, any suggestion would be appreciated. Can you assign a different layer set to this active view only with the construction line layer turned off? Link to comment Share on other sites More sharing options...
mtldesigns Posted 22 hours ago Author Share Posted 22 hours ago 44 minutes ago, JKEdmo said: Can you assign a different layer set to this active view only with the construction line layer turned off? I was wondering if that would work, but I was thinking, wouldn't I just be turning this layer off on the exterior views of the house also? Kinda the same scenario, just a different name. When I get back to that, I will try though.. Link to comment Share on other sites More sharing options...
JKEdmo Posted 22 hours ago Share Posted 22 hours ago 38 minutes ago, mtldesigns said: I was wondering if that would work, but I was thinking, wouldn't I just be turning this layer off on the exterior views of the house also? Kinda the same scenario, just a different name. When I get back to that, I will try though.. You can change the layer set in the camera view settings. I created a duplicate of the Section View Layer Set, but with construction lines turned off. Front elevation camera (no construction lines): Rear elevation camera with construction lines: Link to comment Share on other sites More sharing options...
mtldesigns Posted 21 hours ago Author Share Posted 21 hours ago (edited) Ah, I see what you did. I guess I was going in the wrong direction mentally when I first read your original response. Got it! I'll be back in that model tomorrow, so I will try that. I'm pretty sure that'll fix things. Edited 21 hours ago by mtldesigns Link to comment Share on other sites More sharing options...
joey_martin Posted 6 hours ago Share Posted 6 hours ago Link to comment Share on other sites More sharing options...
