ESINGER7 Posted April 29, 2015 Share Posted April 29, 2015 I would like to use pony walls to create shower enclosures but when I join them as shown the end of the lower wall opens to expose the framing. Is there any way to "cap" the end?? 1 Link to comment Share on other sites More sharing options...
rlackore Posted April 29, 2015 Share Posted April 29, 2015 Did you mean to attach a picture? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 29, 2015 Share Posted April 29, 2015 I use a single thickness wall (just the tile material) the thickness of the desired wall. It won't "frame" but that's not something I'm really concerned about. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 29, 2015 Share Posted April 29, 2015 I came up with a work-round for this in that you make the shower pony-walls, lower wall have whatever material you wish exposed, setting it as that wall types' "Structural Layer" (it is merely a 3D appearance and plays hob with your materials list, if you care about that). I commonly set the structural layer to the same tile material I have on the shower interior walls, so you see tile instead of a fur wood pattern. The upper wall can be centered or placed where you wish via the pony wall - wall type dialog. A secondary method is to cap the transition point of the pony wall with a custom slab, counter top or poly-line solid, both methods are workable and get visual results. DJP 1 Link to comment Share on other sites More sharing options...
ESINGER7 Posted April 29, 2015 Author Share Posted April 29, 2015 Thank you all for responding so fast, and yes I did mean to upload a picture but I guess I didn't. I went with the single layer wall. works great. If you don't mind I have one more question. I'm having trouble getting my wall tile to show up on the material calc. list. I'm new to this part of CA and would appreciate any help u can give me. ES Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 29, 2015 Share Posted April 29, 2015 If you are using the individual Room Material list the tile, drywall, or any other wall material will not show. The Floor and the Total Building Material Lists those things will be included. Link to comment Share on other sites More sharing options...
ESINGER7 Posted April 29, 2015 Author Share Posted April 29, 2015 I also was able to use area polyline. Josh at Tech Supt. said that he will forward this to the developers. ES Link to comment Share on other sites More sharing options...
