kkitch Posted October 20 Share Posted October 20 Hello, I was wondering how to create a macro for roof specifications, mainly, baseline, ridge and top plate height. I can access all the information by opening up each roof plane, but when I'm working on what I consider a complicated roof, it would just be helpful to insert the information on each roof plane as I'm working. Then I could easily use it for reference and comparison purposes. Because my memory isn't very good, I usually have to write down all the information as I'm working to glance at as needed. I created one for room specs that I use often when I'm working on my platforms, but there isn't any information in the macros list to access roof specs. Keith Kitchell Version 18 1 Link to comment Share on other sites More sharing options...
CarrieS Posted October 26 Share Posted October 26 Hi @kkitch , I don't believe we have any of those items set up as NVPs currently. I'll log it in our feature request database. I'll mention that if you have any further feature requests I recommend posting them in the Suggestions discussion since they are generally more visible and are easier for us to track there. Requests shared in General Q&A discussions can sometimes be missed. You'll see the Suggestions discussion right below the General Q&A discussion on the ChiefTalk home page. You can also send feature requests directly to suggestions@chiefarchitect.com if you don't want to post publicly. Have a great day! Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 26 Share Posted October 26 On 10/20/2026 at 12:26 PM, kkitch said: I created one for room specs that I use often when I'm working on my platforms, but there isn't any information in the macros list to access roof specs. just an FYI, if you are on a windows PC, turn on clipboard history. Then the windows key(start menu button)+v, as in win+v will bring up all of the past clipboard items you have copied to select from them. That way you can copy multiple lines and choose from that list in your next roof dbx 1 Link to comment Share on other sites More sharing options...
kkitch Posted October 28 Author Share Posted October 28 Thanks for the replies. Carrie, I was hoping it was something already in the program that I just haven't been able to access. It would be helpful to me as I work, but others may have already figured a better way of doing roofs. Renerabbit, I appreciate your time, and enjoy all your videos & tips. I've learned a lot through them. I do work with a PC, and I will try the work around you suggest. I was just hoping it was something already within the program. I'm not a computer programmer, just an old carpenter trying to learn CA. Weird thing is, most of what I have difficulty drawing, I could frame it quicker than I can draw it. Thanks again, Keith Kitchell CA 18 2 Link to comment Share on other sites More sharing options...
SHCanada2 Posted October 30 Share Posted October 30 On 10/20/2026 at 1:26 PM, kkitch said: I was wondering how to create a macro for roof specifications, mainly, baseline, ridge and top plate height. I can access all the information by opening up each roof plane I would also like this. In the meantime, I take cross sections, and dimension them to the plate, top of fascia, top of heel, and ridge Link to comment Share on other sites More sharing options...
