fcwilt Posted Wednesday at 07:59 PM Share Posted Wednesday at 07:59 PM Hi. I copied the default tool bar and made some changes and made it active. Anytime I start CA it is using my tool bar. Supposedly my toolbar is saved somewhere but I cannot find it. Where is it? Thanks. Frederick Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Wednesday at 08:29 PM Share Posted Wednesday at 08:29 PM (edited) Check the .....\Chief Architect Premier X17 Data\Toolbars folder. The extensions will be .toolbar Edited Wednesday at 08:31 PM by Joe_Carrick Link to comment Share on other sites More sharing options...
fcwilt Posted Wednesday at 11:48 PM Author Share Posted Wednesday at 11:48 PM (edited) I read in the reference manual that they should be there but I am not seeing my custom ones. I do see all of the standard ones. I will do some more tests. Thanks. Frederick Edited Wednesday at 11:48 PM by fcwilt Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Thursday at 03:11 AM Share Posted Thursday at 03:11 AM Have you exported your custom toolbar ? 1 Link to comment Share on other sites More sharing options...
fcwilt Posted Thursday at 06:29 AM Author Share Posted Thursday at 06:29 AM 3 hours ago, Joe_Carrick said: Have you exported your custom toolbar ? I haven't found a way to do that. I don't see it among the various export commands. I see the toolbar import command but there is no export there. Thanks. Frederick Link to comment Share on other sites More sharing options...
rlackore Posted Thursday at 01:44 PM Share Posted Thursday at 01:44 PM 7 hours ago, fcwilt said: I see the toolbar import command but there is no export there. You don't have to export anything. When you create a new toolbar it will be saved in the Current Toolbars Folder. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Thursday at 01:53 PM Share Posted Thursday at 01:53 PM 1 minute ago, rlackore said: You don't have to export anything. When you create a new toolbar it will be saved in the Current Toolbars Folder. So the question is: In waht version did you create it ? Have you migrated from that version ? If not you can still copy that toolbar from the version data/toolbars folder. Link to comment Share on other sites More sharing options...
fcwilt Posted Thursday at 02:36 PM Author Share Posted Thursday at 02:36 PM 49 minutes ago, rlackore said: You don't have to export anything. When you create a new toolbar it will be saved in the Current Toolbars Folder. Hi, Thanks for the reply. See attached. The normal configuration files are there but none of my custom ones are showing up. They appear when using CA, they are just not being saved. Frederick Link to comment Share on other sites More sharing options...
fcwilt Posted Thursday at 02:39 PM Author Share Posted Thursday at 02:39 PM 44 minutes ago, Joe_Carrick said: So the question is: In waht version did you create it ? Have you migrated from that version ? If not you can still copy that toolbar from the version data/toolbars folder. Hi, Thanks for the reply. The custom ones have been created in X17. They work in X17 but are not being saved for some reason. And X17 is not displaying any error message indicating there was an error when saving. Frederick Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Thursday at 04:03 PM Share Posted Thursday at 04:03 PM (edited) Do you have your Data Folder on a Drive other than "C" ? Maybe you are using a secondary drive like Dropbox. I've set mine up to use the "D" drive and Dropbox. What's shown in my "C Drive" isn't complete - it only shows the initial X17 toolbars, not subsequent additions. Otherwise, contact Customer Support. Edited Thursday at 04:05 PM by Joe_Carrick Link to comment Share on other sites More sharing options...
para-CAD Posted Thursday at 04:59 PM Share Posted Thursday at 04:59 PM https://www.chiefarchitect.com/search/?q=toolbars Link to comment Share on other sites More sharing options...
para-CAD Posted Thursday at 05:01 PM Share Posted Thursday at 05:01 PM Link to comment Share on other sites More sharing options...
