I need help with stairs, winders specifically. X10 version.
I am needing help with creating a set of stairs with winders in X10. I would love to speak with someone on a zoom call or something if possible. It probably wouldnt take long. I cant even get the Winders option to show up and I have looked and looked and cant figure this out. I have included a couple of pics, the first is with 3 sets of stairs connected. The second is with the U shape
Posted (edited)
FWIW, X10 is 8 years old and most users here are on X17.  I think in X10 you would probably need to use manually created pie shaped landings to emulate the winders.  You will need to adjust each landing's top elevation & thickness to get them all to connect with the stair sections
As Jason said, questions and requests for assistance should be posted in the Q&A Forum.
Edited by Joe_Carrick
Posted (edited)
There were some changes made to the stair tool about v10 - do you have V10 or v10b?
Try this:
Draw a straight stair section containing the number of winders you need.
Mark them as Winders.
Right click on the stairs ( or left click+Option on a mac) and drag them around to form the winders.
They need to be contained within a room so that the winders can extend out to the walls of the staircase room.
This is in V10:
Edited by glennw
